Headlight Problem
Fsirko
I am having a problem with my headlights on my Rx300. The hi beams are not working. The bulbs are okay and so are the fuses. I am thinking about replacing the Headlight Control Relay but I really don't know if this will fix the problem. Has anybody else had this problem and what did you do to fix it.
  • 8 months later...
For future readers... (2000 RX300)
I also had this problem and also my DRL didnt work.
It was a bad relay in the "fuse block 1" location (there are 3 relays and 1 fuse here). You can troubleshoot by borrowing a good relay from elsewhere. My bad relay was the one closest to the fuse.
PDS
