jpaulmac Posted August 29, 2008 Share Posted August 29, 2008 Would the bleeding pattern on the sc400 the same with the LS400? Left rear, right rear, right front then left front. HELP. Quote Link to comment Share on other sites More sharing options...
john denninger Posted August 30, 2008 Share Posted August 30, 2008 Would the bleeding pattern on the sc400 the same with the LS400? Left rear, right rear, right front then left front. HELP. The conventional thinking was to start with the wheel furthest from the master cylinder and work towards the master cylinder. Subsequent discussion seems to conclude that it really does not make much difference as long as you bleed long enough to replace the fluid in what ever line you are bleeding. Quote Link to comment Share on other sites More sharing options...
