07 Or 08 Ls460/600 Wind Noise
If you are having a "Wind Noise" problem with your 07 or 08 LS460/600 there may be a solution for you at:
http://www.clublexus.com/forums/showthread.php?t=352398
Hi, my name is Francois, I work for Lexus at stevinson, I foud a link that could get you some informations about the causes of wind noise. I hope that this link would be usefull for you.
http://209.103.220.182/class_schedules/FMP...n.htm&-find
If you work at the Stevinson West, in Golden/Lakewood, CO, I can show you the mod Jeff came up with. I live nearby.
It worked for my LS460.
I gave a copy of it to salesman Doug Miner.
Whit
whitbaby@comcast.net
I haven't noticed any type of wind noise what so ever.
I picked up my LS 460 this after noon after having the TSIB NV009-07 performed which for my Vin# included both front glass replaced with Lamisafe glass. I noticed a significant difference. There is still some slight wind noise at speeds of 65-75 mph, however while at the dealership I test drove a late model 08' which has the lamisafe glass installed from the factory and it too had slight wind noise at the same speed range. Interested to know if anyone else has noticed this as well!
Thanks!
Thanks!
The "Wind Noise" problem occurs in the 2007 and 2008 LS460s and LS600s. Manifestations range from slight to severe, left or right or bilateral. The cause is a defect associated with the triangle trim at the corners of the windows in the front doors and some gaps under the trim where air gets in. There is an easy, inexpensive DIY fix. You can read about the fix at the link below. The discussion has grown quite long - many pages -but is interesting and informative through out.
  • 4 months later...
I just purchased a 2006 ls430 and am bothered by a wind noise as well. It is not a whistling sound, but a sound of rushing air that one would hear if the window were slightly open. Do you think the fix for the ls460 would apply to my car?
David
Thanks!
