kh_gs300 Posted August 14, 2008 Share Posted August 14, 2008 once i start the enging or just turn the key one step i start hearing a drilling sound behind the climate control panel or the stereo which last for arounf 30 seconds then it disappears. Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted August 15, 2008 Share Posted August 15, 2008 You're probably just hearing your master cylinder although it could be anything, does it happen right after you press the brakes to put the car into gear? Quote Link to comment Share on other sites More sharing options...
dcfish Posted August 15, 2008 Share Posted August 15, 2008 once i start the enging or just turn the key one step i start hearing a drilling sound behind the climate control panel or the stereo which last for arounf 30 seconds then it disappears. That is your speed sensitive front suspension activating. ;) Quote Link to comment Share on other sites More sharing options...
kh_gs300 Posted August 16, 2008 Author Share Posted August 16, 2008 You're probably just hearing your master cylinder although it could be anything, does it happen right after you press the brakes to put the car into gear? Thanks for your reply. The sound starts once I turn the key (switch) one step before the engine starts. Quote Link to comment Share on other sites More sharing options...
dcfish Posted August 16, 2008 Share Posted August 16, 2008 You're probably just hearing your master cylinder although it could be anything, does it happen right after you press the brakes to put the car into gear? Thanks for your reply. The sound starts once I turn the key (switch) one step before the engine starts. That is correct sir ;) Quote Link to comment Share on other sites More sharing options...
kh_gs300 Posted October 4, 2008 Author Share Posted October 4, 2008 How to stop this sound ? Quote Link to comment Share on other sites More sharing options...
