Changing Low Beam & High Beams Bulbs In 1993 Es300
I am deciding to change my headlight and highbeam lights pretty soon, with these " http://cgi.ebay.com/ebaymotors/Xenon-HID-H...sspagenameZWDVW " can i get a diy on how to do it, i looked at the one ken2323 wrote on the 1998 es300, and as you know they are two different generations, so if i get a diy i would really appriciate it. :)
Changing the headlight (bulbs) on the '93 es300 is easier than easy.
First, you need the bulbs. #9006 for the low beam(s). #9005 for the high beam(s).
I just changed the low beam(s) on mine.
I did find it easier on the passenger side to remove the windshield washer 'bottle' - first. (A couple of bolts w/10 mm heads). Less than 5 minutes.
To remove the bulb(s), unlatch the wiring harness and turn the headlamp bulb. Remove bulb.
To re-install. . . reverse procedure.
HINT: Do NOT touch the bulbs with your bare hands. The oils from your hands will cause premature bulb death.
Total time to swap out the bulbs. . . . 10 minutes, tops.
