Trans
Clyde 1
Ok...New issue has developed with my 93 SC 400. It recently started short shifting thru the entire range of gears, right off the stop it uses 1st ok then long before enuff revs are built ......it shifts to 2nd then into 3rd and on into OD .....making the engine lug terrible
Any suggestions?...I idea's on where to start?
Thx in advance
Clyde
It sounds normal. have you experienced something differently in the past? Also is the engine choking or does it feel like the entire car is jerking while it's changing gears?
No stuttering or abnormal stuff .....in DRIVE it shifts normal 1st to 2nd.....immediately followed by 3rd and OD...without building any revs in between 2nd and 3rd or between 3rd and OD.
Thx again
Clyde
