ono8ono Posted August 10, 2008 Share Posted August 10, 2008 hey guys, some of you may have this same problem: oil leaks from the valve cover on both side. And the oil leaks to the exhaust and smell kind of bad; I wonder how difficult to replace the gasket; I know there is a write up at lexLS.com but that is for '90-'94 LS engine. do you know any write up for '98 LS400? Thank you in advance. :) Quote Link to comment Share on other sites More sharing options...
Harky Posted August 10, 2008 Share Posted August 10, 2008 I had the same problem...cured it by snugging down the valve cover screws. Some of the screws on mine were just finger tight. Gently!! tighten them in a sequencial pattern all the way around a little at a time. Look closely with a flashlight so you don't miss any. Quote Link to comment Share on other sites More sharing options...
ono8ono Posted August 10, 2008 Author Share Posted August 10, 2008 I had the same problem...cured it by snugging down the valve cover screws. Some of the screws on mine were just finger tight. Gently!! tighten them in a sequencial pattern all the way around a little at a time. Look closely with a flashlight so you don't miss any. thank you! I'll try that. Quote Link to comment Share on other sites More sharing options...
ED. Posted August 11, 2008 Share Posted August 11, 2008 Strange they were lose but good deal on the cheap/easy repair. Quote Link to comment Share on other sites More sharing options...
