I HAVE A 92 SC300 THAT I AM PUTTING A 1JZ-GTE ENGINE IN AND I WAS WONDERING WHAT KIND OF DOWN PIPE DO I NEED TO GET? THE FACTORY EXHAUST IS A 2 PIPE 2 BOLT EXHAUST AND THE 1JZ IS A 1 PIPE 3 BOLT.
  • 1 month later...
Hi,
Im cruising a jzz30 with original 1jzgte, so you are right with the downpipe, it seperates after the cat, You should build your own downpipe to get a 3" diameter, stock is smaller & restrictive, the catalitic converter is located in the midpipe, i used a hks midpipe to decat. don´t buy the 1jz downpipe from ebay, it won´t fit, it´s made for the JZA70 MKIII Supra.
good luck!
rocka
