Wiring Diagram For Audio Unit In An Is 300
alexus62
Hello, i am new in this forum. I come from Denmark/Europe.
I own a Lexus IS 200 from 1999. The radio/cassette/CD unit (part nr.: 86120-53040) in it broke down. I bought a used unit from a Lexus IS 300 from 2002 (part nr.: 86120-53120) in USA via ebay.
The problem is, that multiplug from the wiring in my car (18 pins) does not fit multiplug on the "new" unit (20 pins).
Can anyone tell me how the wiringdiagram is on the multiplug on the radio/cassette/CD unit from the Lexus IS 300 from 2002?
(If poosible, can anyone tell me how the wiringdiagram is on the multiplug on the radio/cassette/CD unit from the Lexus IS 200 from 1999?)
Can anyone tell me, if there exists some kind of adaptor to connect these two units?
I will be thankfull for any answer.
Kindly
Alex
I would need a picture of the wiring harness you have in the IS 200 along with the wirring schematic, so I can figure out what the differences are. Does the IS 200 have a seperate amp?
Hello Smooth 1
Thank you for your answer.
I think I now have all the information you ask for, but i am not allowed to mail you on this site, and i dont know how to fill in an image in my reply. I am asked for an URL adres, which i haven't got for my pictures.
Do you have an idea how to get in touch?
If you can inform me how the wiring is on the 86120-53120 audio unit, i am pretty sure, that i will be able to connect the wiring in my car to the "new" unit.
Hope to hear from you again.
Kindly
Alex
Can you upload the picture to photobucket or some pictore storage site like that and then just post a link here?
Hello Smooth 1
I think i just found out how to send pics on this site, so here is hopefully the informations you required.
I also have send you a link to a picture storage.
post-77070-1218388397_thumb.jpgpost-77070-1218388423_thumb.jpgpost-1-1086910734.jpgpost-77070-1218388453_thumb.jpgpost-77070-1218388470_thumb.jpgpost-77070-1218388486_thumb.jpgpost-77070-1218388501_thumb.jpg[attachment
10365:Front.JPG]post-77070-1218388536_thumb.jpgpost-77070-1218388553_thumb.jpg[atta
hment=10368:My_Lexus_and_I.JPG]
Kindly
Ok, let's start with this first:
Is this the radio your putting in or took out? I hope it's the radio you took out. Because that's not an american version IS 300 head unit. That looks like an Altezza radio.
Next, this picture:
The color code operations is:
Cyan/Yellow = Constant 12v power
Grey = Ignition
Green = Illumination
Blue/white = Power antennea
Brown = Ground
Lt. Green + / Lt. Blue - = Right speaker
purple + / pink - = Left speaker
red + / white - = Right rear speaker ( The high, not the woofer)
black + / Yellow - = Left rear speaker (The high not the woofer)
If you indeed have the IS 300 version head unit, I can get you the plugs that fit into the head unit. Then you would just have to cut the harnesses you have off and splice them into the correct socket of the US version harness.
The U.S. version is almost the exact opposite of the one you have there. See how the CD plaeyer in between the knobs and the screen is below that and the cassette player is all the way to the bottom?
Hello mr Smooth1
I am sorry, i first see your reply now.
The picture above is the unit that i took OUT of my car, the one i want til put INTO my car, is exactly the same as the one you show in the picture, see below:
this picture:
Grey = Ignition
Brown = Ground
Then this and the male part of the harness, and the wire diagram for your car should be all you need. Just match the function and color to the correct location on the harness and you good to go.
this picture:
Grey = Ignition
Brown = Ground
Hello mr Smooth1
Thank you for your reply.
Maybe we misunderstand each other because of the language difficulties.
I have the wiring diagram for my car, so what i need is the wiring diagram for the new head unit that comes from the US is300. The colour codes i can understand, and i understand that they are from the US is300 head unit, but i don't know which pin of the male plug / head unit i should connect the wiring from my car to.
I would be very interested in getting the plug, you mentioned it earlier, that would fit in the head unit.
Yours sincirely, and i appologize for the inconvenience
Alex
  • 15 years later...
I matched everything up radio turns on fine plays nice through the front speakers how do I get it to play out of the back? The rear speakers are getting no sound and I double triple checked I followed your colors to the T.
Everything is tied directly in to the amp harness and it turns on and off with the key it plays good through the front but no sound out of the back speakers. Plz help I have OCD and it’s !Removed! me off XD
