2001 Gs 430
um i have HIDS in my high beams (i added them) and i have a separate bulb for the DRL'S plus i have seen people change there DRL'S and get white or even blue lights, so are you sure they just the highs running at half speed? that would make my DRL'S hids in my case and i know for a fact they are just a small bulb think they are 194's!
http://www.sylvania.com/ConsumerProducts/A...LRG-Results.htm
i believe them to be the step/courtesy lights
brian
hmmmm i keep my lights on auto and these lights are ALWAYS on so im just assuming they were! arent the drl's in the high beams..........
brian
Try turning the lights off. The DRLs should be on regardless of the light switch.
ok i did but these still ARENT my high beams . my highs are hid's and these are def a small little bulb
brian
