jpilk99 Posted July 31, 2008 Share Posted July 31, 2008 Sorry for what I believe is a common question & topic. My new, (04'), LS430 just lit up the "Maintenance Required" warning. I know this means to change the oil and then reset the warning. I found out how to reset warning light, but, can find info/pictures on the oil pan drain. I'm sure when I climb under the car it will be self evident but if anyone can educate me first I'd appreciate it. Plus, it sounds like it take 4.6 quarts of 5/30 - is that right? Thanks for any help you can lend. Quote Link to comment Share on other sites More sharing options...
PilotguyPA28 Posted July 31, 2008 Share Posted July 31, 2008 Check your Owner's Manual for the correct amount of oil. I just take mine to Express Oil Change and pay $23 every 5,000 miles. My filter is in a tough spot and extremely hard to get to and they usually spill some on the frame. I make them clean it off with a drying agent. Well worth the $23. I provide an OEM filter. Costs me $5. Quote Link to comment Share on other sites More sharing options...
trevordbs Posted August 1, 2008 Share Posted August 1, 2008 doin it yourself atleast once is always nice In my honest opinion. i have a 78 el camino i do all the work to, but when it comes to this lexus(91 ls400) i take it out for just about everything so far. Quick, easy and you dont have to do the clean up. My book says 5/30 with normal weather, and 10/30 with summer heat. California has been a hot one. ;) Quote Link to comment Share on other sites More sharing options...
