scottelble Posted July 26, 2008 Posted July 26, 2008 Ok, so when i'm coming to a slow stop just before i do my brake peddle depresses and feels as though my abs is kicking in...It's always felt tight and i just noticed a difference. Isn't the abs only supposed to do that if the car thinks it's gonna lock up Which i would assume would be faster than 1mph!
djspawn00 Posted July 26, 2008 Posted July 26, 2008 Are you sure the sensation you are feeling is the a.b.s. kicking in? If its something of a pulsating feeling it could just be warped rotors... if its the full blown a.b.s. vibration then you may have an issue with a wheel speed sensor or something else... I really have no clue but I'd check the warped rotor theory first. Goodluck.
scottelble Posted July 27, 2008 Author Posted July 27, 2008 Are you sure the sensation you are feeling is the a.b.s. kicking in? If its something of a pulsating feeling it could just be warped rotors... if its the full blown a.b.s. vibration then you may have an issue with a wheel speed sensor or something else... I really have no clue but I'd check the warped rotor theory first. Goodluck. It's defidently not the rotors....It's like right before i stop my brake peddle falls...It doesn't hit the floor but it makes me nervous just the same. I'm wondering if my abs motor is going bad?
scottelble Posted July 27, 2008 Author Posted July 27, 2008 I found this thread lastnight...I believe this is my problem b/c it explains my symtoms to a tee: http://www.vr4stealth.com/abs_speed_sensor_cleaning.htm
scottelble Posted July 28, 2008 Author Posted July 28, 2008 I found this thread lastnight...I believe this is my problem b/c it explains my symtoms to a tee:http://www.vr4stealth.com/abs_speed_sensor_cleaning.htm Wow... that's interesting! I thought so myself;)
sakataj Posted July 28, 2008 Posted July 28, 2008 hmmmm so u gonna try it and get back to us? if u do how bout a step by step with photos along the way? brian
scottelble Posted July 28, 2008 Author Posted July 28, 2008 hmmmm so u gonna try it and get back to us? if u do how bout a step by step with photos along the way?brian Easy as cake! Problem solved...Sorry i didn't get to take any pics but all it took was a one phillips screw and it pulls out. We then took a shop rag and wiped the magnet clean and then stuck the corner of the towel down in the hole and spun the rotor a few times to wipe the teeth clean...! 10 minutes tops! FYI: we only did the fronts so i don't know about the backs...SHOOOO, i feel much better:)
sakataj Posted July 29, 2008 Posted July 29, 2008 well good glad u got that problem solved......be a good link to remember in the future if i ever need! brian
scottelble Posted July 30, 2008 Author Posted July 30, 2008 well good glad u got that problem solved......be a good link to remember in the future if i ever need!brian Yes sir ree BOB!! That's a HOT tip right there! :D At $200 a pop for the sensors it was nice to have a 10 minute fix;) Very liberating for my wallet!
sakataj Posted July 30, 2008 Posted July 30, 2008 someone will need this one day and then they will owe u a or two brian
scottelble Posted July 31, 2008 Author Posted July 31, 2008 someone will need this one day and then they will owe u a or two brian I have one(or three) on a daily basis so when that offer comes along i will GLADLY accept!
sakataj Posted July 31, 2008 Posted July 31, 2008 lightweight........... :whistles: :whistles: i mean lush brian
scottelble Posted August 1, 2008 Author Posted August 1, 2008 lightweight........... :whistles: :whistles: i mean lushbrian Lightweight...I wish!!! A lightweight wouldn't have this much overhead(LOL!)...We'll just say my tolerance gets poor gas milage B)
sakataj Posted August 4, 2008 Posted August 4, 2008 well if i ever get to louisville we'll go have a drink or a few brian
