Ok, so when i'm coming to a slow stop just before i do my brake peddle depresses and feels as though my abs is kicking in...It's always felt tight and i just noticed a difference. Isn't the abs only supposed to do that if the car thinks it's gonna lock up Which i would assume would be faster than 1mph!
Are you sure the sensation you are feeling is the a.b.s. kicking in? If its something of a pulsating feeling it could just be warped rotors... if its the full blown a.b.s. vibration then you may have an issue with a wheel speed sensor or something else... I really have no clue but I'd check the warped rotor theory first. Goodluck.
It's defidently not the rotors....It's like right before i stop my brake peddle falls...It doesn't hit the floor but it makes me nervous just the same. I'm wondering if my abs motor is going bad?
hmmmm so u gonna try it and get back to us? if u do how bout a step by step with photos along the way?
brian
brian
Easy as cake! Problem solved...Sorry i didn't get to take any pics but all it took was a one phillips screw and it pulls out. We then took a shop rag and wiped the magnet clean and then stuck the corner of the towel down in the hole and spun the rotor a few times to wipe the teeth clean...! 10 minutes tops! FYI: we only did the fronts so i don't know about the backs...SHOOOO, i feel much better:)
well good glad u got that problem solved......be a good link to remember in the future if i ever need!
brian
brian
Yes sir ree BOB!! That's a HOT tip right there! :D
At $200 a pop for the sensors it was nice to have a 10 minute fix;) Very liberating for my wallet!
someone will need this one day and then they will owe u a :cheers: or two :cheers:
brian
brian
I have one(or three) on a daily basis so when that offer comes along i will GLADLY accept! :cheers:
lightweight........... :unsure: :whistles: :whistles: i mean lush
brian
Lightweight...I wish!!! A lightweight wouldn't have this much overhead(LOL!)...We'll just say my tolerance gets poor gas milage B)
