Smartaccess Problem
diemta
 Share
I have an '04 LS430 with SmartAccess and recently have a problem that the power lock control and window movement control on the driver side do not operate the passenger side in the front. In addition, the side view mirror on the passenger side does not move from the folded position to the open position when the ignition is turned on. Furthermore, the window movement control on the passenger side in the front only operates in the 1st mode (the window only moves when the control is operated), not the 2nd mode (the window goes all the way up or down with a single click of the window movement control). The SmartAccess system no longer operates the passenger door in the front. When the SmartAccess opens the other doors, instead of two beeps, now it's a continual chirps. This car was purchased new in 01/04 and only has about 25,000 miles on it.
Loading...
 Share
