2000 Rx300-how To Change Upper Rear Brake Light?
jtgann
I just did this last night. There is a long piece of plastic on the door that prevents you from getting to the light. It pops off with some prying from a screw driver. Work on the left side of it first. Don't worry you won't break anything. It clips right back on. After getting that off you have access to the upper brake light. Pop that out, two clips keeping it in place Took a little bit of wiggling back and forth to get it out. Put the new bulb in and put it all back together.
