n14t20k11 Posted July 14, 2008 Share Posted July 14, 2008 I'm trying to remove the radio of my 1990 ls400. I got the wood plate off around the shifter and the air outputs. I read online that you need to reach under the ash tray and pull and the clips will release. I did this, but it wouldn't release and i'd like to know if anyone has a better description of what to do or how exeactly to get off the wood plate around the ash tray so I can get to the two lower screws. Any advice would help thanks. Quote Link to comment Share on other sites More sharing options...
raymsixsix Posted July 14, 2008 Share Posted July 14, 2008 Welcome to the LOC n14t! I used these directions to remove the a/c unit on my '95 LS. http://www.lexls.com/tutorials/audio/headunit.html Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted July 14, 2008 Share Posted July 14, 2008 I assume you are following instructions such as these for the 90-94 LS: http://carstereohelp.com/stereoremovalLexusLS400str.htm Maybe you need to pull harder. I removed the radio in the 90 LS I used to have numerous times and don't remember it being difficult to remove the ashtray. If I remember correctly (and I may not!), I think it just snaps into place. Quote Link to comment Share on other sites More sharing options...
