ED. Posted July 11, 2008 Share Posted July 11, 2008 Doesn't the flow start above the filter, pass through then head off to the vents? I wanted it put it in before I left for the office this afternoon but couldn't really read the old one. Sad to say too because I've had it out a lot to clean it. I am shocked at the crap in that thing. It's worse than the engine one! I cleaned both on Sunday but did not have time to install the new one this afternoon. Just the inside one which is carbon. Breathe easy! Who knows what you were getting with that old one... <_< Quote Link to comment Share on other sites More sharing options...
PilotguyPA28 Posted July 11, 2008 Share Posted July 11, 2008 Put it in the same direction the one you took out was turned. Quote Link to comment Share on other sites More sharing options...
Alexander the o.k. Posted July 11, 2008 Share Posted July 11, 2008 Not familiar with your setup, but try taking the filter cover off and turn on the blower for a second or two with your hand over the hole. That should give you a pretty good idea of the direction of flow. Quote Link to comment Share on other sites More sharing options...
GDixon Posted July 11, 2008 Share Posted July 11, 2008 On the RX, the plastic frame that holds the filter has an arrow molded into it on the outside along the edge. It is difficult to see because both the arrow and frame are black. The replacement filter also has an arrow printed on it. Line up the arrows going in the same direction and you are done. Hope your model works the same way. Lexus seems to try to make some of the simpler components interchangeable to a point. Quote Link to comment Share on other sites More sharing options...
