I Got My Lift Delivered Today
silvercorvette
Normally you would just put html tags around the url-
Like this
http://img.photobucket.com/albums/v308/sil...pg?t=1215619525 [ img ]insert url here[/img ] with no spaces.
In this case I got "THE FOLLOWING ERROR(S) WERE FOUND
Sorry, dynamic pages in the %7Boption%7D tags are not allowed"
I don't use photobucket, so not sure what they've done to the page to make it 'dynamic'.
See if it works for you.
Maybe it's a new security thing.
Like this
I got the same message regarding dynamic pages. I have posted many photos from P/B on other forums and this is the first time it ever happened to me
I would really like to do a step by step photo set of the install because it may halp someone else that is thinking about a lift. This is my second lift I left the old one in NY when I sold the house
Like this
Sorry, dynamic pages in the p><p>I don
Here's what you do:
First copy the "img" code at the bottom of the image you've selected at photobucket.
Example:
[imghttp://i291.photobucket.com/albums/ll293/makenpics/WomenTires.jpg' alt='WomenTires.jpg'>
Click on the image button located in the tool bar at the top of your post window. Paste the code into the popup window. Carefully remove the code at the front of the line until it begins with "http" ... now remove the code at the end of the line until it ends with ".jpg" ... it should now look like this:
http://i291.photbucket.com/albums/ll293/makenpics/WomenTires.jpg
then press "ok" . You should see the image in your window. At this point press the "add reply" button to enter your post.
The other way is to paste the entire img line with no modification directly into your window instead of using the image button. Easy Peasy, didn't even have to breath hard. :cheers:
