alufront Posted July 5, 2008 Share Posted July 5, 2008 I own a 1998 Lx upgraded to 2007 with 18inch wheels and lights, for more than a year I have being bleeding the brake sysytem since my brake brake pedal will go low from time to times. The problem is that the first push is low but if you press the brake again it iwll go back to normal level. I have replaced the following: 1- entire master brake system. 2- caliper seals 3- brake rotor( crossdrilled) 4-bleed the system several times using 3 methods scan tool owners repair manual 5 steps gravity bleeding. right after each bleeding the brakes will go back to normal level in the first press, but after a few weeks it iwll go low, please help!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
