Diy - 06 Right Rear Door Lock Actuator R&r
EXCELLENT EXCELLENT write up :cheers: :cheers: BUT why would u have to replace a 2006 actuator? wouldn't that still be covered under the factory warranty or even the extended warranty? you get 5 years factory so y not have them do it?
"i will welcome myself back to the forum as im,woo hooooooooo, finally unsuspended! hahaha!"
brian
I bought the car from CarMax (won't happen again) so I don't think the factory warranty would apply.
I thought I did try opening the door handle, both inside and outside. But I couldn't get it to come out. I knew there was a way to do it but never found anything in my searches about it.
factory warranty should still apply............DID YOU NOT GET A WARRANTY FROM CARMAX? it is a 2 year old car.......i mean they have to offer you something or else the factory warranty is still in effect till it runs out, right?
brian
i would call the dealer (the lexus dealer and not the carmax) and find out if your factory warranty is still in effect!
brian
