01GS300 Posted June 19, 2008 Share Posted June 19, 2008 My '01 GS300 has stock 225/55/16 wheels (Michelin Pilot A/S) and I would like to go to a lower profile tire. I was wondering if the upgrade to 245/45/17's would make much of a difference in handling. Has anyone made that change, is it worth it. I don't think I want to go to an 18" or greater. Quote Link to comment Share on other sites More sharing options...
rickgus Posted June 22, 2008 Share Posted June 22, 2008 Not really answering your question, but I wondered the same thing a few months back. I decided to stay with the 16" rims mainly due to the fact that tire prices take quite a jump when you go to 17" for some stupid reason. Quote Link to comment Share on other sites More sharing options...
01GS300 Posted June 24, 2008 Author Share Posted June 24, 2008 Not really answering your question, but I wondered the same thing a few months back. I decided to stay with the 16" rims mainly due to the fact that tire prices take quite a jump when you go to 17" for some stupid reason. Yes, I haven't checked prices yet but I figured that. I just bought a set of winters on 16" rims so now I have two sets of 16's and will probably stick with them. I'm not big on doing mods but may consider a spring/strut mod somewhere down the road. Quote Link to comment Share on other sites More sharing options...
mlgs300 Posted August 7, 2008 Share Posted August 7, 2008 Wider tires will give you better handling, but you will sacrifice some slight ride quality. I put Eibach springs with Bilstein shocks and the car will corner flat with the stock 16's. I bought some 17" rims from an 07 and am going to install those as well. Quote Link to comment Share on other sites More sharing options...
cb124 Posted August 7, 2008 Share Posted August 7, 2008 the bigger wheels will help handling. if you go with an 18" you will be fine, ride will be great. Quote Link to comment Share on other sites More sharing options...
01GS300 Posted August 14, 2008 Author Share Posted August 14, 2008 Wider tires will give you better handling, but you will sacrifice some slight ride quality. I put Eibach springs with Bilstein shocks and the car will corner flat with the stock 16's. I bought some 17" rims from an 07 and am going to install those as well. I don't know much about the suspension in these cars but do you just need the springs and struts for the front? What's a ball park figure for a spring/strut mod? Are coilovers better?...I believe they are more expensive aren't they. Quote Link to comment Share on other sites More sharing options...
RI-Lex Posted August 14, 2008 Share Posted August 14, 2008 wider with a low profile tire rim set up, will always improve your handling Quote Link to comment Share on other sites More sharing options...
Bwilliams Posted September 17, 2008 Share Posted September 17, 2008 Depends on the cost. If its less than a few hundred bucks I'd say go for it. If not I wouldnt bother. Spending $800 to go up 1 inch in wheel diameter will seem like a terrible idea after you have them on for a few weeks. Might as well spend a few hundred more for some kick !Removed! 18s or 19s. Quote Link to comment Share on other sites More sharing options...
