theoneandonly Posted June 14, 2008 Share Posted June 14, 2008 Does anyone know where the fuel filter is located for a 98 LS400? Is it easily replaced? Quote Link to comment Share on other sites More sharing options...
Bali26 Posted June 15, 2008 Share Posted June 15, 2008 I think Its near the left rear wheelwell. Theres a cover on it. Should be same procedure as 91. Search. Quote Link to comment Share on other sites More sharing options...
paulo57509 Posted June 15, 2008 Share Posted June 15, 2008 According to the 1998 shop manual, the fuel filter is in the fuel tank. Replacing it requires removal of the back seat to gain access to the fuel tank and then removing the fuel pump assembly (pump, regulator and fuel filter) from the fuel tank. Quote Link to comment Share on other sites More sharing options...
theoneandonly Posted June 15, 2008 Author Share Posted June 15, 2008 According to the 1998 shop manual, the fuel filter is in the fuel tank. Replacing it requires removal of the back seat to gain access to the fuel tank and then removing the fuel pump assembly (pump, regulator and fuel filter) from the fuel tank. Thank you - I thought it might be either in the back seat area or the engine. Quote Link to comment Share on other sites More sharing options...
bicol-ini Posted June 15, 2008 Share Posted June 15, 2008 what youre talking about is the fuel pump filter located inside the gas tank, what he needs is the inline fuel filter located in the rear of the vehicle, be careful changing this you might stripped the threads of the fuel tubing (somebody did), here check my thread on how i did this, good luck http://us.lexusownersclub.com/forums/index...c=16958&hl= Quote Link to comment Share on other sites More sharing options...
theoneandonly Posted June 16, 2008 Author Share Posted June 16, 2008 what youre talking about is the fuel pump filter located inside the gas tank, what he needs is the inline fuel filter located in the rear of the vehicle, be careful changing this you might stripped the threads of the fuel tubing (somebody did), here check my thread on how i did this, good luckhttp://us.lexusownersclub.com/forums/index...c=16958&hl= Interesting and informative thread. I appreciate the additional information..thank you for sharing. Quote Link to comment Share on other sites More sharing options...
