mberrett Posted June 2, 2008 Share Posted June 2, 2008 just bought a 1990 LS400 for $3000, man what a car, every thing works, rides like a dream, only thing I've noticed is that when you set the fadder all the way to the front, the speakers in the left, and, right door panels sound really muffled, are they blown? of is there another reason? Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted June 3, 2008 Share Posted June 3, 2008 Try your controls. With treble maxed, what do you hear? Can you hear the tweeters at the corners of the dash? Does adjusting your treble pots make any difference on the back door speakers? If so, then the fronts are likely shot. Quote Link to comment Share on other sites More sharing options...
mberrett Posted June 3, 2008 Author Share Posted June 3, 2008 Try your controls. With treble maxed, what do you hear? Can you hear the tweeters at the corners of the dash? Does adjusting your treble pots make any difference on the back door speakers? If so, then the fronts are likely shot. Yes I've tried every thing, they don't have the rattle that a broken speaker has, and I could see one side, but not both, it almost sounds like a loose connection some where before it splits of to the speakers, I'll have to dive into it and find out, if I find somthing, I'll post it. thanks M Berrett Quote Link to comment Share on other sites More sharing options...
