Steering Loose
I have a 92 sc400. When I turn the wheel the car does not respond until it is turned and additional 10 degrees. Very loose steering. Very scary. This needs to be addressed as soon as possible, but you know mechanics....it could be anything. I was wondering if anyone has had or heard of this problem.
bet its the steering rack bushings
2 fix's
buy new rack
buy off shelf bushings and make fit
get them a little big
like a little bigger
and force them in with a impact.
how i fixed several so far
beleive it or not
i got a set of sway bar bushings for $8.99
from the local parts store shelf
cheap ,easy . probably a short term fix, but it works
if it goes out again i will order some poly bushings
