Hi All,
I own a 98 LS400 and I am considering a wheel upgrade to 20" wheels all around as follows:
Wheel Size: 20x8.5
Bolt Pattern: 5x114.3
Wheel Offset: +42
Tire Size (F & R): 245-35-20
My question is do I need to roll the LIP of the fender to make this type of set up fit. Also please note that I recently upgraded my shocks to Bilstein shocks in which I do not know if it will have an adverse effect on this application or not.
Thanks for your feed back
Al.
I had 20" wheels on my old 91LS lowered almost 2" on Tanabe DF210's. Never rubbed. I forget the offset and all that technical info though..
You need to make sure the wheels will fit over your brakes the offset does tno tell you.
Thanks SKP. I am aware of this...I just need to know if the 20" will go on fine without any rubbing to fender.
