dscabicky Posted May 6, 2008 Share Posted May 6, 2008 I had a new battery installed and since then the ignition often clicks when I turn it. If I keep trying it will eventually catch. I assume a loose cable but not sure how to find it. They seem tight but I can't see down to the solenoid connection. Is there any way to test to find out what the problem is? I replaced the terminal connection on the positive side because the Lexus one was a little big around the post even when completely tightened. Didn't hel :( p. Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted May 6, 2008 Share Posted May 6, 2008 I had a new battery installed and since then the ignition often clicks when I turn it. If I keep trying it will eventually catch. I assume a loose cable but not sure how to find it. They seem tight but I can't see down to the solenoid connection. Is there any way to test to find out what the problem is? I replaced the terminal connection on the positive side because the Lexus one was a little big around the post even when completely tightened. Didn't hel :( p. There are many many threads on this problem. Use the search feature. You will find all the tests you need to do and info on repairs. Quote Link to comment Share on other sites More sharing options...
