Stuck Thermostat
mywong23
01 LS430, 107K
WP & TB changed at 90K,
on freeway, wife spotted temp guage climbing towards H...
I test drive with same symptoms, both fans spinning, radiator full of coolant.
turn on heater on HOT; to help lower coolant temp.
bought new thermostat from Lexus Concord, they even matched Toyota's price ($4 less) :)
swapped in new gasket & t-stat.
temp back to normal (halfway) :D
put old t-stat in hot water, heated to boiling.
did NOT open....
  • 2 months later...
01 LS430, 107K
did NOT open....
is this a replacement you made yourself?
i'm doing some routine maintainance on my 1993 ls400 but can't locate the thermostat.
any help would be appriciated
I changed the thermostat on my 94LS with a cheapie simply because at the time, I had several other problems, and wanted to be sure the 'stat wasn't a problem. So I left it in, and have had no problems. I think Paris Hilton could change it out-top hose at the engine block. The only thing I can think of is that it might be installed backwards, or it's the wrong one. Best of luck.
Good to hear that your wife has an observing eye. On a car that new- many people would never even think to look at the gauge for overheating. I do catch myself occasionally glancing at mine from time to time.
Does that car have a chime that sounds when the engine overheats, or when a warning light illuminates?
01 LS430, 107K
did NOT open....
