Scott in VA Posted May 4, 2008 Posted May 4, 2008 The manual for my '08 GS460 says I can raise all windows and close sunroof by pressing and holding the lock button on the door handle (vs. on the remote.) I've not been able to make this feature work. Has anyone tested it and successfully used the feature? Does anyone believe the lack of operation could be related to personal settings? It's a cool feature and I'd love to use, but I'm beginning to suspect it does not exist and is an error in the manual. Have not talked to dealer about it yet. Thanks in advance-
SKperformance Posted May 5, 2008 Posted May 5, 2008 It should be default to work that way , if not drop by the dealer to allow the option. You do have to press and hold the button until they are fully closed.
Scott in VA Posted May 6, 2008 Author Posted May 6, 2008 It should be default to work that way , if not drop by the dealer to allow the option. You do have to press and hold the button until they are fully closed. Thanks, I'll give that a try
