Replace Oem Sub!
I'm looking for an aftermarket sub that will fit in the hole the oem sub came in. Also, i need a good amp to go with it, any suggestions?
I really don't want to put too much money into it though
Thanks!
can you measure the actual dept my tech site says that its a 4" depth I was wondering if you could possibly fit 5 " depth. if not you could use a shallow sub. Kenwood Cadence there are a lot of options. I would recommend something with hight sensitivity then you can use less power to get great sound. I hope this helps.
thats for all the help! I think I'm set on an xplod amp and a pioneer shallow depth sub. From what I heard it's supposed to be good. I'm an audiophile but with the tight budget i think this will be perfect for my needs
