jlasontran Posted May 3, 2008 Share Posted May 3, 2008 Well for some odd reason when i start the car on, their is a strange clicking sound which you can hear inside and outside of the car. But once you step on the clutch the sound is gone. Can anyone tell me what is going on? thank you Quote Link to comment Share on other sites More sharing options...
Tomj8 Posted May 4, 2008 Share Posted May 4, 2008 Well for some odd reason when i start the car on, their is a strange clicking sound which you can hear inside and outside of the car. But once you step on the clutch the sound is gone. Can anyone tell me what is going on? thank you Sounds like the clutch throwout bearing. Noise with no pressure on the clutch pedal suggests the clutch may be improperly adjusted such that the clutch fingers are riding on the bearing constantly, and there should be clearance so that the bearing is clear of the fingers when the clutch is engaged - or you may simply have one that has worn out from use. Throwout bearings are sealed units designed for intermittent load only, and being spun constantly will heat the bearing and quickly put wear on it. An early sign of wear is looseness in the bearing and it isn't uncommon for a noisy throwout bearing to go quiet when pressure is applied to the clutch pedal. Quote Link to comment Share on other sites More sharing options...
jlasontran Posted May 5, 2008 Author Share Posted May 5, 2008 Well for some odd reason when i start the car on, their is a strange clicking sound which you can hear inside and outside of the car. But once you step on the clutch the sound is gone. Can anyone tell me what is going on? thank you Sounds like the clutch throwout bearing. Noise with no pressure on the clutch pedal suggests the clutch may be improperly adjusted such that the clutch fingers are riding on the bearing constantly, and there should be clearance so that the bearing is clear of the fingers when the clutch is engaged - or you may simply have one that has worn out from use. Throwout bearings are sealed units designed for intermittent load only, and being spun constantly will heat the bearing and quickly put wear on it. An early sign of wear is looseness in the bearing and it isn't uncommon for a noisy throwout bearing to go quiet when pressure is applied to the clutch pedal. thanks for the advice. I appreciate it. Quote Link to comment Share on other sites More sharing options...
jlasontran Posted May 6, 2008 Author Share Posted May 6, 2008 Wait so what should/do to fix that problem? Quote Link to comment Share on other sites More sharing options...
