Speedometer & Rpm Gauge... Help
next time one or the other acts up, smack the side of the dash right above the right side of the cluster... see if that makes it work... if so, then what it is, is the metal screws on the back of the cluster. remove the cluster with ignition off, and take a soldering iron to the 5 screws on both sides. they have metal seats under the screws very common problem. just put a drop or two of solder between the screw and the seat. then u should be good.
Hey there, i was wondering what is a soldering iron?
Loading...
 Share
