whitesnake SC400 Posted May 1, 2008 Share Posted May 1, 2008 Hi, i would love to install spacers onto rear wheels. Everything stock - no suspension drop, original fenders, rear tires 225/55/16 stock. Can i go up to 25mm spacer or any other size? Thanks so much for your help. Quote Link to comment Share on other sites More sharing options...
xaine Posted May 2, 2008 Share Posted May 2, 2008 Hi,i would love to install spacers onto rear wheels. Everything stock - no suspension drop, original fenders, rear tires 225/55/16 stock. Can i go up to 25mm spacer or any other size? Thanks so much for your help. i dont suggest using spacers. can cause vibration. and too big of a spacer you have to extend the lug stud. but if you do, i wouldnt go more than a 1/4 inch, to be safe Quote Link to comment Share on other sites More sharing options...
whitesnake SC400 Posted May 2, 2008 Author Share Posted May 2, 2008 Thank you. I've seen some US MADE aluminum spacers on ebay (there are many of them in a range under 70$ a pair) which is claimed vibration free and the issue of replacing lug studs is solved. Check it out http://cgi.ebay.com/ebaymotors/20MM-WHEEL-...sspagenameZWDVW Quote Link to comment Share on other sites More sharing options...
