Trunk
Jerriej
 Share
Have you got both the master key and valet key? The valet key won't open the trunk manually, and if the trunk lock is on the release latch inside won't work either (especially if the battery is dead). Try the other keys manually in the trunk if you have them.
valet key can not open trunk and glove box, its only for the ignition, while master key can open all. its likely that you have the valet key
do i have to get the master key from the dealership or can i get get it for cheaper somewhere else
Loading...
 Share
