portsmouthva Posted April 8, 2008 Share Posted April 8, 2008 Hello my ls has been parked for about a mouth now, every other day i would start it up to let it run, today i went to crank it up and it didnt start, its done this before when a parked it then one day it just started with no problem, any ideas thanks..only parked it to save on gas Quote Link to comment Share on other sites More sharing options...
bigste Posted April 8, 2008 Share Posted April 8, 2008 Sounds like a bad earth. Remove the battery terminals and clean them really good, both the clamps and battery posts. Quote Link to comment Share on other sites More sharing options...
fiveofakind Posted April 9, 2008 Share Posted April 9, 2008 I agree...clean your terminals.....& secure tight Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted April 10, 2008 Share Posted April 10, 2008 Make sure when you run it that you get the engine up to normal operating temps berfore you shut her down. Otherwise you're going to get condensation. Quote Link to comment Share on other sites More sharing options...
portsmouthva Posted April 10, 2008 Author Share Posted April 10, 2008 thanks for the replies but i have a new battery and terminals, i have no idea what the problem could be, when it started up the last time i took it to be look at, and nothing was found no c.e.l. etc, could condensation be a cause Quote Link to comment Share on other sites More sharing options...
lenore Posted April 10, 2008 Share Posted April 10, 2008 Does it try to start, Do you hear the engine turn over.????if not it could be the starter solenoid is bad. If so it could be this: http://www.nationsautoelectric.com/instructions.html Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted April 11, 2008 Share Posted April 11, 2008 thanks for the replies but i have a new battery and terminals, i have no idea what the problem could be, when it started up the last time i took it to be look at, and nothing was found no c.e.l. etc, could condensation be a cause Portsmouthva, new batteries have been known to be defective. Do a load test on your battery. If the battery is ok, then you need to check out your charging, ignition and fuel delivery systems. There are many informative threads on all of these and how to test them. You just need to do a bit of research. Quote Link to comment Share on other sites More sharing options...
chilkoot Posted April 11, 2008 Share Posted April 11, 2008 I got the same thing occasionally (about 3 times in the past year), my LS has had no other issues starting and I replaced the battery with a titanium something or other from Advance a year ago (it was like $80 and 1.5x the size of the battery that was already in there, it's a monster.) but the car still occasionally died on me, like completely losing power less than 15 minutes after I had just shut it down. I would turn the key and get about 1/8sec of dash lights and everything electrical would cut out completely, including locks and lights every time disconnecting the positive wire and making sure it was connected very securely made her start right up. no visible corrosion on the terminals, but I suspect it had something to do with large amounts of engine vibration messing with the connection before i fixed my mounts. Quote Link to comment Share on other sites More sharing options...
beneux Posted April 11, 2008 Share Posted April 11, 2008 Sure sounds like a bad ground. i have a 93 ls400, had the similar problem. the local shop even replaced a 400.00 computer and it didn't take care of the problem. finally i checke the resistance on the negative cable and found out that it was way out of the normal range. i cleaned all the ground connections to the battery and chasis and it worked perfect. Quote Link to comment Share on other sites More sharing options...
drg1cfo Posted April 20, 2008 Share Posted April 20, 2008 Check your timing belt to see & make sure it has not snapped off, it will never even try to start, if timing belt is good check your compression on left and right bank Quote Link to comment Share on other sites More sharing options...
lextuned Posted April 20, 2008 Share Posted April 20, 2008 Check your timing belt to see & make sure it has not snapped off, it will never even try to start, if timing belt is good check your compression on left and right bank could be alternator, starter, or a disease. Quote Link to comment Share on other sites More sharing options...
