I Didn't Know This.
Gravity
If you press unlock once the drivers door unlocks. And if you press it again all doors unlock. No big surprise.
But did you know, that if you press and hold the unlock button again all your windows go down and your sunroof (if you have one) will open.
That I didn't know.
G
That should have been one of the first tricks your dealership should have shown you! I remember when I test drove an RX300 back in 2000 the sales lady showed me that feature right away.
Another trick, ONE-TOUCH START. You don't have to hold the key when starting the car. ;) Just turn it real quick and let go! :)
Thats correct. Also, if you put your key in the driver's or passenger's door lock and hold it in the lock position, it will close all windows and sunroof.
Hmmm, my 07 GX doesn't have a key hole on the passenger side. I believe it's to prevent theft since that is the side most thiefs use to break into a vehicle.
