Power Steering Squeek
I have a 2003 Es 300 and as of about one week ago, my steering wheel started to squeek everytime I turn. I checked the power steering fluid and that is full. I am thinking it might be a bushing but wanted to see if anyone else had a similar issue. Any help is appreciated. Thanks
It is where the rubber boot is that the shaft that connects the steering wheel to the rack. Where the intermediate shaft turns against the rubber is where it comes from. You can take it to the dealer for a free fix. At least I never charge for that. Actually, my whole team doesn't charge for that.
You can use wet silicone spray, but I used a small bit of lithium grease to keep it from coming back. It's greased from the factory anyways.
