boostedis300 Posted March 11, 2008 Share Posted March 11, 2008 i think my little lights in the headlight are burned out. how can i replace them? Quote Link to comment Share on other sites More sharing options...
brosnibean Posted March 12, 2008 Share Posted March 12, 2008 i think my little lights in the headlight are burned out. how can i replace them? pop the hood and you can see the connection on the back of the headlight....rotate the plug counter-clockwise (i think, hey, i hava a 50/50 shot here) and it will pull out...replace bulb and stick it back in and you are done..... check lexus buld reference guide for the correct bulb.....you are looking for the parking light 168 ps - these are the parking lights, so check to make sure they are really burned out before replacing (since you said "i think" they are burned out) pss - i stole the link from here Quote Link to comment Share on other sites More sharing options...
boostedis300 Posted March 13, 2008 Author Share Posted March 13, 2008 thanks, do you have a picture of what i need to rotate? thanks Quote Link to comment Share on other sites More sharing options...
brosnibean Posted March 14, 2008 Share Posted March 14, 2008 thanks, do you have a picture of what i need to rotate?thanks I am replacing the bulbs on mine tonight, so i will snap some peectures and post them....... Quote Link to comment Share on other sites More sharing options...
boostedis300 Posted March 14, 2008 Author Share Posted March 14, 2008 alright, thanks man. Quote Link to comment Share on other sites More sharing options...
brosnibean Posted March 14, 2008 Share Posted March 14, 2008 twist the housing counter-clockwise pull it out, change the bulb stick it in stick it in stick it in i used these 921-x9 from superbrightleds.com Quote Link to comment Share on other sites More sharing options...
boostedis300 Posted March 15, 2008 Author Share Posted March 15, 2008 thanks, that helped. i took out the bulbs and they are not burned out... when do these damn lights come on?? i know they are parking lights but i mean WTF!!!! ive never seen them on. how can i test them? or see them in action>>??? ANYONE????? :( Quote Link to comment Share on other sites More sharing options...
brosnibean Posted March 17, 2008 Share Posted March 17, 2008 thanks, that helped. i took out the bulbs and they are not burned out... when do these damn lights come on?? i know they are parking lights but i mean WTF!!!! ive never seen them on. how can i test them? or see them in action>>??? ANYONE????? :( move the lights switch (on the turn signal arm) to the off position, the first setting/click up is the parking lights...they should come on then, but with standard bulbs you will have to bend over to see them, they are not bright at all....if they are not on then replace the bulbs and work from there..... this is all in your owner's manual Quote Link to comment Share on other sites More sharing options...
boostedis300 Posted March 18, 2008 Author Share Posted March 18, 2008 thanks for the info dude. Quote Link to comment Share on other sites More sharing options...
boostedis300 Posted March 20, 2008 Author Share Posted March 20, 2008 thanks man, the problem was that the lights were burned out... i bought normal replacement lights. thanks again. Quote Link to comment Share on other sites More sharing options...
spetsnaz56 Posted April 7, 2008 Share Posted April 7, 2008 twist the housing counter-clockwise pull it out, change the bulb stick it in stick it in stick it in i used these 921-x9 from superbrightleds.com I was thinking about gettign these but there is a meessage saying this on there "Warning: do not use in headlamp housings - heat will cause LED failure and VOID WARRANTY ! " Quote Link to comment Share on other sites More sharing options...
Lexus2D Posted April 7, 2008 Share Posted April 7, 2008 Iv got LED in mine & have had no problems ;) its the indicators that dont blink correct but that cab be corrected ;) I did mine & im a Girl lol Iv got LED`s all over my Lex Quote Link to comment Share on other sites More sharing options...
IndyKen Posted April 9, 2008 Share Posted April 9, 2008 Me too. Mine also said don't use them in a heated housing but no problems ever. They are just CTA so they don't have to replace a 3 cent item which they charge a few bucks for. Quote Link to comment Share on other sites More sharing options...
spetsnaz56 Posted April 19, 2008 Share Posted April 19, 2008 twist the housing counter-clockwise pull it out, change the bulb stick it in stick it in stick it in i used these 921-x9 from superbrightleds.com What color bulbs did you use. White or blue? Quote Link to comment Share on other sites More sharing options...
smooth1 Posted April 19, 2008 Share Posted April 19, 2008 I think he used red and green. ^_^ Quote Link to comment Share on other sites More sharing options...
brosnibean Posted April 24, 2008 Share Posted April 24, 2008 What color bulbs did you use. White or blue? white... the "don't use in the heated housing blah blah blah" is a total CYA move...standard fare for after-market parts...like the "for off-road use only" statements....i would love see the donkey that puts a set of headers on his/her IS and takes it off-road.... Quote Link to comment Share on other sites More sharing options...
bartkat Posted April 24, 2008 Share Posted April 24, 2008 What color bulbs did you use. White or blue? white... the "don't use in the heated housing blah blah blah" is a total CYA move...standard fare for after-market parts...like the "for off-road use only" statements....i would love see the donkey that puts a set of headers on his/her IS and takes it off-road.... Uh, race track is off road. Quote Link to comment Share on other sites More sharing options...
