LynnW4604 Posted March 10, 2008 Share Posted March 10, 2008 Can someone help me sync my Palm Centro with my 2007 Rx 350? I had a Sanyo before and had no problem syncing to my Lexus. I've tried everything and have no place to turn! I've followed the directions of my phone manual and my phone even says my it has synced but the screen on my Lexus says it hasn't connected. Thanks! Quote Link to comment Share on other sites More sharing options...
clif payne Posted March 11, 2008 Share Posted March 11, 2008 If your Palm is a 700 series this will probably work. If it is not you will not be able to connect your Palm. Pair your Palm just as you have been doing. When your Palm says that is connected but the car doesn't show that it is connected simply dial a number from your Palm. The system will then recognize the connection and the Palm with be connected and you will have the call come through the sound system. Then stop and restart the car to verify that it is making the connection at start up. Be sure that you have made your Palm visible and trusted. I hope this helps. Please post a reply of your experience. Quote Link to comment Share on other sites More sharing options...
LynnW4604 Posted March 11, 2008 Author Share Posted March 11, 2008 If your Palm is a 700 series this will probably work. If it is not you will not be able to connect your Palm.Pair your Palm just as you have been doing. When your Palm says that is connected but the car doesn't show that it is connected simply dial a number from your Palm. The system will then recognize the connection and the Palm with be connected and you will have the call come through the sound system. Then stop and restart the car to verify that it is making the connection at start up. Be sure that you have made your Palm visible and trusted. I hope this helps. Please post a reply of your experience. Thank you so much. I had almost given up. Don't know how you figured it out but...thanks! PS I'm Birmingham, AL also. Mtn. Brook. Have a great day. Quote Link to comment Share on other sites More sharing options...
clif payne Posted March 15, 2008 Share Posted March 15, 2008 If your Palm is a 700 series this will probably work. If it is not you will not be able to connect your Palm.Pair your Palm just as you have been doing. When your Palm says that is connected but the car doesn't show that it is connected simply dial a number from your Palm. The system will then recognize the connection and the Palm with be connected and you will have the call come through the sound system. Then stop and restart the car to verify that it is making the connection at start up. Be sure that you have made your Palm visible and trusted. I hope this helps. Please post a reply of your experience. Thank you so much. I had almost given up. Don't know how you figured it out but...thanks! PS I'm Birmingham, AL also. Mtn. Brook. Have a great day. I'm the product specialist for Tom Williams Lexus and I am an RX400h owner as well. Quote Link to comment Share on other sites More sharing options...
shwonder Posted March 19, 2008 Share Posted March 19, 2008 I have bluetooth problem with Nokia 8800. Have to fully reconnent every time I get in car. Has anybody faced with the similar issue ? Quote Link to comment Share on other sites More sharing options...
rx350guy Posted April 27, 2008 Share Posted April 27, 2008 I have bluetooth problem with Nokia 8800. Have to fully reconnent every time I get in car. Has anybody faced with the similar issue ? What do you mean by 'fully reconnect'? My Motorola RAZR connects automatically each time the car is started, as long as Bluetooth on the phone is powered on.. Quote Link to comment Share on other sites More sharing options...
shwonder Posted April 28, 2008 Share Posted April 28, 2008 I have bluetooth problem with Nokia 8800. Have to fully reconnent every time I get in car. Has anybody faced with the similar issue ? What do you mean by 'fully reconnect'? My Motorola RAZR connects automatically each time the car is started, as long as Bluetooth on the phone is powered on.. I mean have to connect again every time when i enter car. also i do not see my phone in the list after connection. Quote Link to comment Share on other sites More sharing options...
OdessDude Posted May 29, 2008 Share Posted May 29, 2008 I just got 09 RX350. Tried to connect Palm 700p and iPhone - both connect but DON'T register, meaning I can talk through the car speaker, but the bluetooth screen on lexus shows that no phones are registered, although after restarting the car I can still talk through bluetooth. Also, I can only connect 1 phone at a time. If i tried to connect another phone, the first one disconnects. When I was testdriving RX 400H, iPhone connected and registered. Very annoying. Any ideas? Quote Link to comment Share on other sites More sharing options...
OdessDude Posted July 28, 2008 Share Posted July 28, 2008 I just got 09 RX350. Tried to connect Palm 700p and iPhone - both connect but DON'T register, meaning I can talk through the car speaker, but the bluetooth screen on lexus shows that no phones are registered, although after restarting the car I can still talk through bluetooth. Also, I can only connect 1 phone at a time. If i tried to connect another phone, the first one disconnects. When I was testdriving RX 400H, iPhone connected and registered. Very annoying. Any ideas? I have the same problem with my RX 350 '09 - iPhone and Palm treo 700. Very annoying, especially after the no-cell law in California. Any help would be appriciated. Quote Link to comment Share on other sites More sharing options...
Joesky Posted December 25, 2008 Share Posted December 25, 2008 OK the fix is simple. First turn off your phone. Then turn on the blue tooth feature for both the phone and car. Once you put in the pass key in the phone, hit ok. The phone should say that it recognizes the car. The Car will say its still not connected. Then turn on the phone and dial a number. It shouls connect. It work with my Centro and LS460. Quote Link to comment Share on other sites More sharing options...
leboh Posted October 25, 2009 Share Posted October 25, 2009 If your Palm is a 700 series this will probably work. If it is not you will not be able to connect your Palm.Pair your Palm just as you have been doing. When your Palm says that is connected but the car doesn't show that it is connected simply dial a number from your Palm. The system will then recognize the connection and the Palm with be connected and you will have the call come through the sound system. Then stop and restart the car to verify that it is making the connection at start up. Be sure that you have made your Palm visible and trusted. I hope this helps. Please post a reply of your experience. This worked great. I must have read both Lexus and Palm manual for over an hour trying to figure it out. They were no help, but your suggest worked wonderfully. Next time I'm coming right to the forum. Quote Link to comment Share on other sites More sharing options...
harry42ka1 Posted October 10, 2012 Share Posted October 10, 2012 just joined the club today! this is for Clif Payne! hope you can help i have 09 RX350 and iphone 4. (1) i cannot transfer phone book to the car. everytime i try, the bluetooth gets disconnected. i tried this with a BB as well. same result. Any remedy! (2) I have manually entered some phone numbers to the car, when i receive a call, it does not display the name. only number is displayed. Any clue! i will appreicate any help. Quote Link to comment Share on other sites More sharing options...
kawie Posted June 21, 2013 Share Posted June 21, 2013 I have a problem with my Iphone 5. It connects via Bluetooth however it cant transfer data so my phone book does not sync. Any Ideas on this? I am also trying to connect an Ipod touch via Bluetooth. I cant seem to find the Blue Tooth Audio settings in the 2007 model. Any ideas? Thanks david Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted June 21, 2013 Share Posted June 21, 2013 I have a problem with my Iphone 5. It connects via Bluetooth however it cant transfer data so my phone book does not sync. Any Ideas on this? I am also trying to connect an Ipod touch via Bluetooth. I cant seem to find the Blue Tooth Audio settings in the 2007 model. Any ideas? Thanks david 2010 was the first model year that Bluetooth A2DP audio streaming was available in the RX. The iPhone 5 cannot sync its phone numbers with a 2007 RX nav system - you can view which features do work at https://secure.drivers.lexus.com/lexusdrivers/info/my-lexus/resources/bluetooth.do, Quote Link to comment Share on other sites More sharing options...
