techmech74 Posted February 27, 2008 Share Posted February 27, 2008 What are your preferences for new rotors for a 1995 LS400? Stock, drilled or slotted? Ceramic or semi-metallic pads? Recommendations for vendors and/or prices? Has anyone purchased rotors from a specific vendor on e-bay? Thanks- techmech74 Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted February 27, 2008 Share Posted February 27, 2008 I hear iRotor is good for drilled/slotteds. Full ceramic pads no question! Quote Link to comment Share on other sites More sharing options...
VMF Posted February 27, 2008 Share Posted February 27, 2008 a year ago i changed rotors and pads and shims and it made such a big difference you would not even beleive. btw i used all stock parts. they are cheap if you buy them online and with your 4 piston front calipers it doesnt really matter if you use drilled or slotted unless of course you are a really aggressive driver and tend to overheat your brakes or want to stop on the dime. slotted rotors will reduce your pad life by a lot and drilled rotors, if not drilled in proper locations can disintegrate and seriously damage your car. ive seen this on my friends maxima and it was not pretty. Quote Link to comment Share on other sites More sharing options...
NavarreteJason@yahoo.com Posted February 27, 2008 Share Posted February 27, 2008 you can put on the supra big brake kit from stop tech. it will look cool. but if you do that you will need to have a bigger wheal(19'and up) Quote Link to comment Share on other sites More sharing options...
VMF Posted February 27, 2008 Share Posted February 27, 2008 you can put on the supra big brake kit from stop tech. it will look cool. but if you do that you will need to have a bigger wheal(19'and up) your 93 LS has a completely different caliper and rotor your has only 1 or 2 pistons, while 95 and up has 4 pistons in the caliper, 2 on each side. the stock rotor size is 13 inch. stock supra size is 12 inch at least thats what my friends 89 supra has. so im not sure how second gen LS would benefit from using supra brake kit. plus its not an easy job to convert it. i think supra is using 4 lug pattern while ls is 5 lug. Quote Link to comment Share on other sites More sharing options...
