hockeyguy007 Posted January 31, 2003 Share Posted January 31, 2003 My mom recently expressed a need for greater sq in her car after driving my car around for a few days. I was just wondering if you guys had any install tips for me, specifficaly how to remove the factory tweeters and where the factroy amp is located. Any info is apprecaited. Quote Link to comment Share on other sites More sharing options...
gslx4s Posted May 12, 2003 Share Posted May 12, 2003 My mom recently expressed a need for greater sq in her car after driving my car around for a few days. I was just wondering if you guys had any install tips for me, specifficaly how to remove the factory tweeters and where the factroy amp is located. Any info is apprecaited. The factory amp is usualy located behind the glove box. Here is the problem, generaly one won't work with out the other from what i have seen. What io mean is that the factory head unit would rely on the amp inorder to work. You may want to go to a stereo shop and find out more information this. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted May 13, 2003 Share Posted May 13, 2003 i am guessing you have an es but i can't guess what year actually the stock amp for most es 300 are under the passenger frnt seat the deck will also work with out the amp( just loses a beep noise when buttons are pressed as i have used mine old head unit with out the amp for 3 years the tweeters in the sail fins are easy to remove just one bolt beind them to unscrew the panel pops towards you to remove unless you speak of the ones in the corner of the dash called squakers they are useless to replace so don't Quote Link to comment Share on other sites More sharing options...
HoeBag Posted June 1, 2003 Share Posted June 1, 2003 the amp for a 97+ es300 is located behind the glove box Quote Link to comment Share on other sites More sharing options...
