Lo Tire Pressure Warning
Due to several errant road nails, I had to have my tire patched and switched the spare to the L front position. Even though the tires are at the proper pressure (all 5 by the onboard sensor as well as external check) the tire replaced is highlighted in yellow on the display ( at 33 psi) and lo pressure warning is display. What gives?
You have to reset the tire pressure warning system as follows:
PS: the tire pressure warning "set" switch is way under the dash to the right of the steering colume.
Push the START/STOP button until
the vehicle is in the “IG-ON” mode,
and then push and hold the Tire
Pressure Warning “SET” switch for
3 seconds until the Low Tire Pressure
Warning Light blinks 3 times and
then turns OFF to set the tire
pressure initialization.
NOTE:
Make sure that the “Tire Pressure
Reset Proceeding” appears on the
multi-information display. After a few
seconds, the display changes to
“CHECKING” (which means the tire
pressures are being measured).
It is necessary for the ignition to be
in the “IG-ON” mode a maximum of
5 minutes for initialization to
complete correctly.
8. Check that the tire pressures for
all 5 tires is displayed on the
If the tire pressure values are NOT
displayed on the multi-information
display, the initialization is
NOT complete.
NOTE:
Check that the tire pressure adjusted
in step 6 is displayed.
Initialization will be completed if
signals are received from all 5 tires.
It takes 2 to 3 minutes to display the
tire pressure data.
Good luck
