04 Ls430 Rear Parking Sensor Problem
LS430forme
Sorry for the delay, I was traveling and then came back with a cold (just love O'Hare in the winter!). I'll assume the front sensors are working, since that means that all the parts common to both front and rear are OK. See the attached, it looks like you might have a problem with the common ground as about the only thing that would take out all the rear sensors simultaneously. I'd try grounding the individual sensors directly to the chassis and see if that brings them back into operation.Lexus_Wiring_Diagram_372.pdf
  • 14 years later...
This is an add on question. Have one missing rear sensor (RH) and looking to buy from Rock Auto. Question is when fitted will the sensor system accept and function OK with a non genuine? The Rock Auto (V70720226) one is German made and designated as outer sensor.
