BigBuggie Posted February 6, 2008 Share Posted February 6, 2008 Hello again guys. Ok, Just noticed something. My dome light seems to be operating strangely. If I select on it always works. However, when set to door mode, It only works sometimes. This is also in coordination with the door ajar light in the cluster, They only seem to work about half of the time. ....Seems as if they are more likely to work after I close the hood....? Sincerely, Pete Quote Link to comment Share on other sites More sharing options...
aarman4 Posted February 6, 2008 Share Posted February 6, 2008 bigbuggie, Your door sensor switches are very similar to those on a refridgerator... A little button that the door pushes in when it is closed... The contacts for the button are most likely dirty. or perhaps the plkunger portion of it is sticky occasionally. Take a good look at it. Quote Link to comment Share on other sites More sharing options...
blake918 Posted February 6, 2008 Share Posted February 6, 2008 Agreed, you either need to lubricate or replace your courtesy switches on your doors: http://www.lexls.com/tutorials/electrical/fcourtesy.html Quote Link to comment Share on other sites More sharing options...
BigBuggie Posted February 6, 2008 Author Share Posted February 6, 2008 Yes sir. Will do, Right now actually.... ^_^ BTW, Is there anyway to change my name? I don't know what I was thinking letting my little brother choose for me. Quote Link to comment Share on other sites More sharing options...
blake918 Posted February 6, 2008 Share Posted February 6, 2008 Sure, if you want to change your name, send our forum Administrator "Steve" a PM, and he'll get you taken care of. Quote Link to comment Share on other sites More sharing options...
Bali26 Posted February 6, 2008 Share Posted February 6, 2008 You dont need to remove the whole switch out. Just pull back the rubber cover on it GENTLY and spray some WD40 in it. Do all 4. Quote Link to comment Share on other sites More sharing options...
aarman4 Posted February 6, 2008 Share Posted February 6, 2008 I kind of like the name..... Quote Link to comment Share on other sites More sharing options...
BigBuggie Posted February 7, 2008 Author Share Posted February 7, 2008 I kind of like the name..... LOL thanks. I did pull the ruber and spray. Worked great thanks! Quote Link to comment Share on other sites More sharing options...
