1 More Quickie.
BigBuggie
 Share
Hello again guys.
Ok, Just noticed something. My dome light seems to be operating strangely. If I select on it always works. However, when set to door mode, It only works sometimes. This is also in coordination with the door ajar light in the cluster, They only seem to work about half of the time.
....Seems as if they are more likely to work after I close the hood....?
Sincerely, Pete
bigbuggie,
Your door sensor switches are very similar to those on a refridgerator... A little button that the door pushes in when it is closed... The contacts for the button are most likely dirty. or perhaps the plkunger portion of it is sticky occasionally. Take a good look at it.
Loading...
 Share
