How Long To Get Rid Of Check Engine Light After Fuel Tank Cap Was Repl
suraj
:chairshot:
Recently I fill up in a gas station, and forgot to put the gas cap on.
The worst part is that the cap is not attached to the vehicle like all other cars I drove, so it dropped somewhere.
I found it when the check engine light came on after a day. So, I had to replace it from Oreilly's.
I still see the check engine light.
Does anyone have similar experience?
How long will it take to have proper gas tank pressure and get rid of that light?
thanks for your opinion.
:chairshot:
Disconnect the neg. battery terminal for 5 minutes and reconnect, CEL Gone :cheers:
Ok will try that once I get off from work.
I am just afraid whether the Oreilly's after market ($8) gas cap is good replacement for the lexus dealer's $25 gas cap.
thank you for your suggestion.
