Radio/dvd Failure
vetteman
2001 Lexus LX-470
One speaker in back, forget which side, starting making scratching/popping noises.
Using Fade/side controls at radio, ignored the problem hoping I could sometime open the panel and check the speaker.
Then, radio/dvd all went out with no sound whatsoever
Then, very, very loud static/popping/cracking sound from speaker system mostly at startup for about 3 minutes but then randomly later when driven.
Took to dealer, said amplifier was probably the issue.
$850 for new amp and then they could further analyze.
Getting varying/suspect quotes from aftermarket installers that require new amp, new wiring, and even new radio/dvd.
Any and all ideas appreciated..
2001 Lexus LX-470
I'll see if I have an amp for you, If I do it will be alot less expensive than $850
2001 Lexus LX-470
vetteman, Check your messages. I have a amp for you. :cheers:
  • 4 months later...
2001 Lexus LX-470
$1350.00 for new amp and then they could further analyze.
DOES ANYONE KNOW WHERE I CAN GET THE LEVINSON AMP REPAIRED?? OR WHERE I CAN BUY ONE THAT IS NOT FROM THE DEALER?
THANKS
2001 Lexus LX-470
THANKS
I have a ML amp if you are still looking for one.
  • 6 months later...
There were some problems with some early ML amps and were covered under a TSIB. There are several vendors that will service a Lexus unit, but it is good to support a fellow LOC member since the chance to have good customer satisfaction is excellent.
