Recommendations For An After Market Stereo Face Plate For '97 Es30
I just installed an after market stereo in my '97 ES 300 because my LCD was delaminating. I figured a $110 for a Dual XHD6425 was better than the cost of replacing the LCD for my 10 year old stereo.
Anyway, Crutchfield sent me the wrong mounting kit. They sent one for a 1996 Lexus. it's only one year different but apparently Lexus swapped the order of the A/C unit and the stereo.
It turns out (many of you probably know this) that the ES300 stereo is just a dual DIN unit, so my new stereo installed just fine. However, now I have this large hole in my dash because I don't have a face plate. Crutchfield doesn't sell one for my car.
So I thought I'd ask here.
Since my stereo is a single DIN I'd like a face plate with a cubby slot for throwing keys and such. I may have to order these separately. I really want it to match the look and texture of the factory plates so that it still matches my A/C and clock units.
I'm sure many many people here have already done this. Can anyone recommend where I can get these? Model numbers or urls would be great.
Thanks!
Matt
Thanks!
Matt
I think that this 2001 kit might work (Scosche Part Number: LS2075B)
http://www.scosche.com/products/productID/121
I used their 1997-2000 double DIN kit for our 2000 ES300 and it works fine.
Hope that helps...
Thanks! That one looks great.
Do you know how it mounts in the dash? Does it screw into the DIN bracket or does it mount some other way?
Thanks,
Matt
Thanks!
Matt
Hope that helps...
I remember the double DIN kit used the same install dash screws/points as the factory double DIN radio.
Here's a picture of the double DIN bracket - not much to it:
Thanks,
Matt
