BigBuggie Posted February 3, 2008 Report Share Posted February 3, 2008 Hello again, I figured I'd post this one while I remember it. My steering wheel is slightly off center when driving straight. I have read about a shifted R+P housing as the origin of this problem. Is there a quick fix? Perhaps a tutorial on a readjustment? The steering feels great, No vibrations and the speed sensitivity seems right on. It's just the wheel is a bit out and it is bothering me :( Is this something that I can/should solve when I install my new steering wheel? Is this issue in anyway associated with an alignment? I would think not... Thanks again, Pete Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted February 3, 2008 Report Share Posted February 3, 2008 When you let go of the wheel when you're going straight does it pull to one side? If so it's an alignment issue. But if the car drives straight and the steering wheel is crooked I'd think someone may have removed it.. Unless there's a reason the wheel would just go crooked without an alignment problem... Quote Link to comment Share on other sites More sharing options...
BigBuggie Posted February 3, 2008 Author Report Share Posted February 3, 2008 The car pulls slightly to the left when I let it go. All other aspects feel normal. Its such a small pull I didn't give it much thought. I have read that with this generation LS the rack and pinion housing may shift slightly causing this effect. I figured there would be other symptoms associated with such a contingency, not just an out of center wheel. I guess I'll have to look into it more. Thanks, peter Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted February 4, 2008 Report Share Posted February 4, 2008 How long has it been since your last alignment?? I'd say get another one done...if it has been a while it definately wouldn't hurt anything to give it a try. Quote Link to comment Share on other sites More sharing options...
Bali26 Posted February 4, 2008 Report Share Posted February 4, 2008 I had the same problem alignment, fixed it. Quote Link to comment Share on other sites More sharing options...
BigBuggie Posted February 4, 2008 Author Report Share Posted February 4, 2008 very good, Will try that. Probaly wait until I get a wheel. First. Thanks, pete Quote Link to comment Share on other sites More sharing options...
