jimmyj466 Posted February 2, 2008 Report Share Posted February 2, 2008 replaced the starter in the 93LS went to start, she cranks and and fires but then dies, got the, 15 - Ignition no. 2 signal, on the trouble code, what and where is the number 2 ignition? I had to take the cluster out to check my check engine light, and found that the bulb was missing, someone didn't like to see it, or they didn't want me to see it. the holder was there but the bulb was gone. i'm affraid this might be just the begining to getting her back up and running, any and all help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted February 2, 2008 Report Share Posted February 2, 2008 When did you buy the car? Can you get them on a lemon law?? Sounds like a pretty illegal sheister move to me to remove the CEL bulb! Quote Link to comment Share on other sites More sharing options...
Leadfoot Posted February 2, 2008 Report Share Posted February 2, 2008 replaced the starter in the 93LS went to start, she cranks and and fires but then dies, got the, 15 - Ignition no. 2 signal, onthe trouble code, what and where is the number 2 ignition? I had to take the cluster out to check my check engine light, and found that the bulb was missing, someone didn't like to see it, or they didn't want me to see it. the holder was there but the bulb was gone. i'm affraid this might be just the begining to getting her back up and running, any and all help would be greatly appreciated. That code indicates you have a fault in the igniter circuit on the right bank (sitting in the drivers seat looking forward the right bank is on the right) Please refer the attached procedure (for a '92 but it will be the same) which, along with everything else for your car, is available for download from www.techinfo.toyota.com for $10/24hr access. If you have no spark I would jump straight to step 7 and check the coil. If thats OK then go back to step 4 and follow the instructions. Let us know how you get on. dtc1415.pdf Quote Link to comment Share on other sites More sharing options...
jimmyj466 Posted February 3, 2008 Author Report Share Posted February 3, 2008 Leadfoot, Thanks so much for the info, it worked out great, loose wire on the coil. this site rocks!!!! Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted February 3, 2008 Report Share Posted February 3, 2008 Glad to hear you got it working properly!!! :D Quote Link to comment Share on other sites More sharing options...
