Wont Start
churchlex
im graduating school this year got this 98 ls 400 in August last night i started it she ran perfectly this morning i got up turns over but no start what is a possible problem lonely in virginia
With a spark ignition internal combustion engine there are two things that always need to be checked first, fuel and spark.
1) Do you have fuel pressure at the injector rails? have a look at the attached file and get someone to help you check that there is fuel pressure in the line shown.
2) Do you have spark? have a look at the attached procedure and see if all is as it should be.
Report back your findings for further help.
All the info you could ever want is available at www.techinfo.toyota.com, $10 for 24hr access and you can download untill your finger siezes.
Good luck.
IG_1_ovi.pdf
SF_5_ovi.pdf
